1. Create several operands
I often want to create several comparable signals at mixed locations.
In this case this function is not very usefull because the addresses (in DBs) can not be modified afterwards.
As alternative/remedy, a copy function for signals is missing.
In general (e.g. signal, project): copy-functions (to generate a duplicate as starting-point for a new instance) are lacking.
2. Order of properties
Is it possible to change the order of properties to:
Data block - Address or even better: Data block.Address (just one field)
Unit - Symbol - Commentary (instead of Unit - Commentary - Symbol)
All according the symbollist of Simatic - Step7
Create new signal
